September 1, 2019, 01:44 |
Simulation of liquid evaporation
There is a tank filled with helium. The tank wall is multilayered, composed of some solid domains.
Liquid hydrogen is supplied to the tank, and then hydrogen begins to evaporate when it contacts with the warm walls. When the tank is filled with liquid hydrogen, the supply stops and the tank is maintained for a certain time. The purpose of modeling is to make sure that the insulation is selected correctly, near-wall fluid layers do not boil during maintaining. I use two fluids in the fluid domain: 1) helium (pure substation) 2) hydrogen (homogenous binary mixture), but I’ve received the following error:equilibrium phase in one phase in a multiphase run is not supported by the solver for this combination of thermodynamic states. what multiphase model can you advise for this case? |
September 1, 2019, 07:16 |
Rep Power: 143 |
Why do you need CFD for this? Why are empirical correlations and some hand calculations not sufficient?
Boiling simulations are difficult and even harder to get accurate. Getting it more accurate than a good hand calculation will probably be difficult. But to answer your question - have you looked at the tutorial examples? I would also contact ANSYS support as they have additional examples and will probably have something close to your case.
Solid Liquid Simulation FLuent | sandisk | FLUENT | 3 | November 9, 2017 01:11 |
Liquid Fuel Combustion Simulation - need some guidance | sa007057 | FLUENT | 0 | September 15, 2014 13:57 |
CFX Liquid Evaporation Model | Jinx | CFX | 3 | January 28, 2010 16:31 |
evaporation on the surface of liquid nitrogen | dodo | FLUENT | 0 | March 3, 2008 04:37 |
evaporation from liquid surface to ullage? | prasanth | FLUENT | 0 | May 22, 2003 08:22 |
