Dear all Gurus
In the Ansys Workbench 8.1 at the generate CFX- mesh part, after the mane of 2D regions were specified and I would like to create the 2D meash. In order to make this 2D mesh, I know that the following procedure must be done first. : Mesh > Options > Meshing Strategy > Chang Advanced Front and Inflation to Extruded 2D mesh. Unfortunately, I did not see the Options > Meshing Strategy > Chang Advanced Front and Inflation to Extruded 2D mesh, in my Tree view. Where is this procedure? Especially at the step Meshing Strategy, Where is it? or I did something wrong. Please point me the way and give me the comments as well as the suggestion to create 2D mesh. With the best regards, Dome. |
I have my monitor display set to a high resolution and large fonts. This changes the way some dialog boxes are displayed, and I remember the Extruded 2D mesh combo box only shows one option, so the Extruded 2D mesh option is not visible. The work-around is to use the up and down toggles to flick between the options. Glenn Horrocks |
I've been told that the Extruded 2D Mesh Option is NEW for ANSYS 9 Workbench. It is NOT available in ANSYS 8.1 Sorry! I have 8.1 and it doesn't have the Extruded 2D Mesh Option. You aren't missing anything because you don't have it.
thank you very much Sandra
exporting the modified mesh from ansys | dogo1234 | ANSYS Meshing & Geometry | 1 | September 5, 2013 11:08 |
importing mesh from Gambit and other software to ansys workbench | mortazavi | CFX | 12 | May 30, 2012 07:38 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
importing mesh from Gambit and other software to ansys workbench | mortazavi | ANSYS Meshing & Geometry | 5 | June 6, 2011 11:09 |
importing mesh to ansys workbench??? | mortazavi | ANSYS | 0 | June 1, 2009 05:10 |
