November 23, 2018, 04:22 |
Prepare Table on Results
Marcin
Rep Power: 9 |
Transient analysis in CFX.
How to create a table in which to read the value of the expressions for each Step, as you can do for a chart. I need to make the equation of the function of two variables (expressions). |
November 23, 2018, 04:58 |
urosgrivc
Rep Power: 11 |
in post you make a graf of your expression against time than click export data you then get a table that can be opened by excel.
Usually there are some weird numbers so you have to divide everything by 10ˇ8 still don't know why If you monitor data in solver manager you can also click on the graph in the solution manager and export data points |
November 23, 2018, 06:55 |
Marcin
Rep Power: 9 |
Thank for help. It works.
cfx, chart, table |
Multiphase simulation with RPG table | Lucy089 | CFX | 8 | October 16, 2018 01:57 |
Problem in3D model processing | mebinitap | OpenFOAM | 2 | December 12, 2014 04:40 |
Transient Run - Output "Time" in partial results? | evcelica | CFX | 2 | May 16, 2012 21:36 |
transient results chart or table | haconk | CFX | 1 | May 6, 2009 02:49 |
Table Manipulation | furkan | Siemens | 0 | April 4, 2006 10:23 |
