Pump unphysical efficiency
Like Tree1Likes
  • 1 Post By Gert-Jan
Old   December 8, 2018, 18:58
Default Pump unphysical efficiency
Lilian Chabannes
Lookid is on a distinguished road
I compute a low specific speed pump with splitter blades. Inlet + Full impeller + Volute. No casing.
Periodically, I have an hydraulic efficiency > 1, it happens when the main blade (sometimes the splitter also) passes in front of the cutwater. The average efficiency is somehow realistic (~0.77)
I changed the mesh - the turbulence model - the boundary conditions, but I always have the same results (exact same amplitude). So I believe there is 3 ways out of this :
1 - My CFD is still wrong
2 - CFD can't model this case (I'm really not experienced enough to pretend this, just putting it here)
3 - It's physical, and if I try to explain it, here I go :
Citing Gulich, chap 10.1 :
"When the blade passes under the diffuser vane or volute cutwater, there is a pressure minimum due to the effect that the fluid is kind of “squeezed” through gap B"
In my case, this whole pressure minimum is present on the whole channel (see image, in this image, the efficiency is > 1). So locally (at this time), this low pressure on the pressure side causes a low torque > a low shaft power which is locally lower than water power > an efficiency higher than 1.
► Note on the impeller: It's a low specific speed impeller (nq = 9, high diameter, lot of blades), but the outlet width is way higher than the "recommended" one. b2 recommended is 4mm, I have 10mm. So basically, even at the designed point, my impeller behaves like a "part-load" classic impeller.
Any comments is appreciated because I am completely stuck right now
Feel free to join the OpenFOAM Discord https://discord.gg/P9p9eHn, a live chat about OpenFOAM
Lookid is offline   Reply With Quote
Old   December 9, 2018, 05:16
If the hydraulic efficiency > 1 for just a tiny fraction of the rotation, is that significant? I suspect not. You say the average efficient is realistic at 0.77, so isn't that the important factor?
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   December 9, 2018, 05:32
Lilian Chabannes
I agree with you (because I hope it's ok ^^). But if the prediction is unphysical "some times", how to trust the results the rest of the time?
I am wondering if something like that is measurable on a tests-rig, but I didn't see it on any papers obviously.
The picture I showed is a 5+5 bladed impeller. For a 4+4, the "shock" was more violent, and the efficiency was up to 1.5 .
Old   December 9, 2018, 14:35
Gert-Jan
Gert-Jan will become famous soon enough
It is difficult to judge your case, but I used to perform calculation on fish-friendly pumps with only 1 blade. There I see this happening all the time because at a certain moment in time the torque is low, while the flow is high, resulting in efficiencies above 1. On average, the efficiency matches experimental values very well.
Gert-Jan is offline   Reply With Quote
Old   December 9, 2018, 16:24
Lilian Chabannes
@Gert-Jan, nice! As you say, it doesn't mean it is also true with my case, but if someone experienced it before with good comparison with experiment it's already really nice and gives me hope ))). Thanks for your reply.
For info, what was your CFD efficiency peak? 1.1? 1.5?
On the experiments, you saw that efficiency peak also? Or you measured just the average?
Old   December 9, 2018, 18:05
Gert-Jan
The maximum is about 110%:
I get time averages back from the pump manufacturer. And the values are within 1% (absolute)
Lookid likes this.
Old   December 11, 2018, 08:44
Lilian Chabannes
Thanks!
I did not understand if the value you sent were from the manufacturer, or are your CFD values?
Old   December 12, 2018, 02:54
Gert-Jan
I only received average numbers from the manufacturer and that is clearly not what you see in the graph......
Pump numerical efficiency fluent Ahmed Saeed Mansour FLUENT 0 September 7, 2017 13:54
centrifugal Pump Efficiency A.farid Main CFD Forum 0 March 31, 2012 07:39
How to define hydraulic or total efficiency in a centrifugal pump? spk FLUENT 11 March 29, 2012 05:36
Improve the efficiency of pump Raja CFX 0 December 26, 2008 02:53
Pump efficiency john FLUENT 1 February 26, 2008 05:48
