Obtaining forces from Transient Results
Old   July 19, 2005, 18:15
Default Obtaining forces from Transient Results
Meri
Hello, I just completed a transient simulation on a wing that took a long time. I just realised that I messed up on the monitor points, my axis are z-up,x-longit and Y transverse or into the page, when I wanted force_x()@Wing I wrote force_y()@wing instead, now the problem is I need this forces over the simulation time, is there a way in CFX-Post I can have the right forces exported over time ? I will appreciate any help. Thanks
Old   July 19, 2005, 18:40
Default Re: Obtaining forces from Transient Results
For any transient results files you generated as the simulation progressed you can calculate CEL functions in CFX Post and will be able to get the forces (Provided the required variables are in the transient results file). If you did not save any transient results files then the information is lost, you will have to rerun the simulation.
Old   July 20, 2005, 01:28
Meri
Thanks Glenn, I do have transient result files, but I set the option to minimal and then the variables I would like to see, is this what you mean ? how do I check if those forces are there ? any guidance on writing CEL? have never done one b4
Old   July 20, 2005, 18:21
You don't need to write a CEL expression as long as it is a simple function. You can calculate the basic functions directly using the tools/function calculator.
To get a force acting on the body the calculator will need pressure (for pressure forces) and wall shear (for viscous forces) in the transient results file. If it is not present in the file then it will not be able to calculate it.
How can I export transient results data to EXCEL popi CFX 8 February 22, 2014 04:31
Error writing transient results in FSI Pocket CFX 1 April 15, 2010 06:57
transient results N.R. CFX 0 October 22, 2007 13:07
Transient Results Ogbeni CFX 5 November 30, 2004 09:43
attaching transient results files houman CFX 5 June 25, 2004 07:42
