import iges file to icem
Old   August 8, 2005, 13:29
Default import iges file to icem
jack
Hi, everyone;
I am a newer, when I imported <.iges > file to Icemcfd, error message appeared as" child killed : segmentation violation". Anyone can help me for that, thanks in advance!!!
jack
Old   August 8, 2005, 18:40
Default Re: import iges file to icem
Is it a big model? You may have run out of memory. Alternately, try using a different format (STEP, ACIS etc).
Old   August 16, 2005, 23:53
Default I encounterd same prob. in Linux
Tina
Hi, 1. I encountered the same problem in Linux (CentOS 3.5), but it's ok in windows 2000. 2. It will show " child killed : segmentation violation" even it's a small iges file. note: the other function of icemcfd are good in linux.
Does anybody has same experience as me?
Old   September 3, 2005, 06:05
Default I know what's wrong now!
Tina
Just update the ICEM_CFD to sp1 then it's ok now!
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' mfiandor OpenFOAM Installation 2 January 25, 2010 09:50
[OpenFOAM] ParaView 33 canbt open OpenFoam file hariya03 ParaView 7 September 25, 2008 17:33
[OpenFOAM] Paraview command not found hardy ParaView 7 September 18, 2008 04:59
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
