modeling of a pulsejet in flight
Old   August 30, 2005, 17:31
Default modeling of a pulsejet in flight
Tony
We want to model a pulsejet engine in flight. To make this simple suppose the jet is flying at a constant speed of 30m/s. The pulsejet has an inlet facing to the flight direction. Air enters the pulsejet through the inlet and react with fuel in the combustion chamber. I am not sure what kind of boundary conditions should be specified at the pulsejet inlet and the outlet. For the static case, we specified 'total pressure'at the inlet and the outlet.
Thanks.
Modeling a pulsejet and an ejector Emmanuel FLUENT 0 May 24, 2006 18:53
May Focus Area: Turbulence Modeling Jonas Larsson CFD-Wiki 0 May 2, 2006 11:48
Modeling Flow/Saturation/Absorption in Fibers Gene Dougherty Main CFD Forum 0 June 6, 2003 14:49
CFD Modeling of Two-phase Flow in Small Dia.Tubes Eric Poindexter Main CFD Forum 2 September 22, 2000 09:21
Help With Modeling A Projectile Fluid In Flight. Dzeff G. Main CFD Forum 0 December 10, 1998 21:24
