March 15, 2019, 11:33 |
Table or polynomial boundary condition
Luka Vincekovic
Rep Power: 7 |
Hi all,
I am trying to insert flow direction as boundary condition via table. As far as I realised this can't be done. It is either value or expression, right? So my question is, if I have a table which for example, describes some boundary condition what is the best way to import it as an expression? Can someone please explain the procedure? Let's say that we start from 100x100 values x-y table which describes total pressure. How do you get polynomial and import it in CFX? I attached how the pressure looks like when you plot it in MATLAB. Thanks, Luka |
March 15, 2019, 11:38 |
Rep Power: 32 |
In ANSYS CFX, a table is an expression via a function. Check the documentation for how functions work in expressions.
March 15, 2019, 11:41 |
Luka Vincekovic
Rep Power: 7 |
Yeah, I managed to get an expression working but it doesn't show what I want.
Do you have an idea how to describe attached contour with polynomial that would work? Thanks |
March 15, 2019, 18:03 |
Rep Power: 143 |
You could use a 3D interpolation function, a polynomial which describes the function as a CEL expression or a user fortran routine to define it. CFX has lots of ways to do it.
March 18, 2019, 11:34 |
Erik
Rep Power: 23 |
Yes, there are lots of ways to do it.
Easiest would be the 3D interpolation function that uses your 100x100 table directly. Make it a function of (x,1,z) format your table with 4 columns, using: x, 1, z, PressureValue. Then make an expression for P_inlet which would be a call to the function: PressureFunction(x,1,z). To make a polynomial, you will have to develop an equation for a 2D surface, which is difficult, and usually not very accurate for complex surfaces. |
March 19, 2019, 04:30 |
Luka Vincekovic
Rep Power: 7 |
Thank you all for the help, just a quick update.
I managed to import all the data as a table at the end. It is possible to import also the velocity direction as a table. I did a bit of reverse engineering. So in CFX Post you can see what data you can export from your boundaries and all these data can be imported as a table into CFX Pre. So I took a table from CFX Post and just changed the values with what I needed and put it into CFX Pre. |
March 20, 2019, 12:15 |
Erik
Rep Power: 23 |
Yes you can import velocity as a table, or just about anything else you wish.
cfx, polynomial bc, polynomial eqn. |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
Problem in setting Boundary Condition | Madhatter92 | CFX | 12 | January 12, 2016 04:39 |
several fields modified by single boundary condition | schröder | OpenFOAM Programming & Development | 3 | April 21, 2015 05:09 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
