March 15, 2019, 07:28 |
User Fortran environment set up
phd
Rep Power: 12 |
Hi, there
In order to use User Fortran I have set up my win7 computer with CFX 17.2 in the following manner: installed Intel Parallel Studio XE 2017, Update 4 + Microsoft Visual Studio Community 2017 with 'Desktop development with C++' component In my computer. But sadly, when I ran the command of "C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2017.4. 210\windows\bin\ifortvars.bat" intel64 %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% It replied: Intel(R) MPI Library 2017 Update 3 for Windows* Target Build Environment for Int el(R) 64 applications Copyright (C) 2007-2017 Intel Corporation. All rights reserved. ERROR: Visual Studio 2012, 2013, 2015 or 2017 is not found in the system. %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% Could kindly give me some suggestions on resolving this problem? Do I need to do some set up for Visual Studio 2017 other than installing it following the instruction? Thank you very much! |
March 19, 2019, 15:18 |
phd
Rep Power: 12 |
I have installed the VS2013 and Intel XE 2015, update2. Now after running the magic word of:
"C:\Program Files (x86)\Intel\Composer XE\bin\ifortvars.bat" intel64 It says: Intel(R) Parallel Studio XE 2015 Copyright (C) 1985-2015 Intel Corporation. All rights reserved. Intel(R) Parallel Studio XE 2015 Update 2 Composer Edition (package 179) So, I guess I can User Fortran now. I will try to run some tutorial to see if I can work. Some tips for the newbies from my side are: 1) VS 2013 can be downloaded only when you subscribe the Visual Studio Dev Essentials; 2) VS 2013 must be installed before Intel XE, because when VS2013 is not installed beforehand, Intel XE’s product integrations with VS 2013 will not be installed. |
user fortran |
[ICEM] ICEM Scripting Issues | tylerplowright | ANSYS Meshing & Geometry | 33 | September 27, 2021 16:35 |
If a sample line coincides with faces, the user should set the set the sample line?? | Hojae | OpenFOAM | 3 | November 29, 2014 05:48 |
Comparison between C/C++ and Fortran? | rick | Main CFD Forum | 45 | September 6, 2011 00:52 |
CFX11 + Fortran compiler ? | Mohan | CFX | 20 | March 30, 2011 18:56 |
User Fortran and interior node information | John | CFX | 0 | August 26, 2008 22:24 |
