CFX 4:USRSRC
Old   September 8, 2005, 19:12
Default CFX 4:USRSRC
RK
Can someone suggest what is wrong with the following statement? It is causing a divergence at present.
C ADD SOURCE TERM C....+R1 is added to enthalpy equation C C Check if R1 is positive or negative
IF (R1.GE.0) THEN
SU(INODE,IPHASE)=SU(INODE,IPHASE)+R1*VOL(INODE)
ELSE SU(INODE,IPHASE)=SU(INODE,IPHASE)-R1*VOL(INODE)
ENDIF
Checking R1 values, there are some values that -ive values, while some have +ive values!
Many Thanks,
RK
Old   September 10, 2005, 10:51
Default Re: CFX 4:USRSRC
Jeff
If the sources are either positive or negative, then that's what they are. Arbitrarily negating the negative values to make them all positive isn't physical.
Sources should ALWAYS be added, whether they are positive or negative.
Jeff
[ICEM] Proper way to name boundaries on 2D model for use in CFX? RossFS ANSYS Meshing & Geometry 4 November 10, 2011 02:38
Pros and Cons for CFX, CFdesign, COMSOL Val Main CFD Forum 3 June 10, 2011 02:20
CFX pressure in Simulations problem nasdak CFX 1 April 14, 2010 13:22
PhD using CFX Rui CFX 9 May 28, 2007 05:59
CFX 4.4 installation problem Pandu Sattvika CFX 1 December 1, 2001 04:07
