November 24, 2005, 09:06 |
polyline
I was trying to generate polylines using the following .cse session file. I am using this on CFX to simulate flow through a T piece pipe. At every cross-section i am taking 15 points to get the velocities.
The program runs fine for the negative x axis value but doesnt produce any results in the positive x axis. Results are good in the y aix also. The orientation is like a inverted T along positive X and Y axes with one half of the T in the -ve xaxis. # A CFX-Post session file for output of Values along Polylines defined by a file # ################################################## ############################# # # Creating a Polyline # ################################################## ############################# ! sub PLineOut { ! ($XStart, $YStart, $ZStart, $XEnd, $YEnd, $ZEnd, $NrPts, $VarString, $OutFileName) = @_; ! $DeltaX = ($XEnd - $XStart)/$NrPts; ! $DeltaY = ($YEnd - $YStart)/$NrPts; ! $DeltaZ = ($ZEnd - $ZStart)/$NrPts; ! open(LPOINTSFH,">LinePts.txt"); ! for($Pcnt=0; $Pcnt<=$NrPts; $Pcnt++){ ! $XAct = $XStart + $DeltaX * $Pcnt; ! $YAct = $YStart + $DeltaY * $Pcnt; ! $ZAct = $ZStart + $DeltaZ * $Pcnt; ! print LPOINTSFH "$XAct $YAct $ZAct\n"; ! } ! close(LPOINTSFH); POLYLINE:PolyPoints Apply Instancing Transform = On Boundary List = Default Colour = 1, 1, 1 Colour Mode = Constant Colour Variable = Pressure Domain List = All Domains Input File = LinePts.txt Instancing Transform = Default Transform Line Width = 1 Location = IsoCylinder Max = 0 [kg m^-1 s^-2] Min = 0 [kg m^-1 s^-2] Option = From File Range = Global Visibility = On END > forceupdate PolyPoints EXPORT: Include Header = On Null Token = <null> Precision = 8 Separator = " " Vector Brackets = () Vector Display = Components Export File = $OutFileName Location List = PolyPoints Overwrite = On Variable List = $VarString END :export ! return 0; ! } # ####program inputs # ! $NrOfPoints = 15; ! $Diameter = 0.03; ! $SF = 0.99; ! @XList = (-10.5, -1.5, -1, -0.75, -0.5, -0.25, 0, 0.5, 1.5, 2.5, 4.5); ! @YList = (1, 1.1, 1.25, 1.5, 2.1, 2.5, 3, 3.5,6); ! $R2 = $Diameter * $SF * 0.5; ! foreach $XC(@XList){ ! $FName = "out_" . $XC . ".dat"; ! $XDim = $XC * $Diameter; ! PLineOut($XDim, 0.0, 0, $XDim, $Diameter, 0, $NrOfPoints, "Y, Velo\ city u, Velocity v", $FName); ! } ! foreach $YC(@YList){ ! $FName = "out_b_" . $YC . ".dat"; ! $YDim = $YC * $Diameter; ! PLineOut(-$R2, $YDim, 0, $R2, $YDim, 0, $NrOfPoints, "X, Velo\ city u, Velocity v", $FName); ! } |
CFD-Post: Polyline Export at Integration Points | minger | ANSYS | 4 | February 22, 2014 09:23 |
Polyline at intersection of two planes | Francesco | CFX | 2 | July 29, 2009 08:03 |
Help Needed: Polyline intersection in Post | PHabib | CFX | 4 | July 13, 2009 04:04 |
about polyline and the coordinates | Eric | CFX | 1 | July 12, 2006 22:01 |
plot variable against length of polyline | Francesco | CFX | 0 | April 4, 2006 11:49 |
