pump FSI
Old   June 17, 2019, 06:56
Smile pump FSI
Yining CHEN
Yining CHEN is on a distinguished road
Hello!
I am new about FSI simulation.
I simulate a periodic domain of the pump's rotor and stator from a 3D CAD file.
The procedure is...
3D cad file -> create periodic and fluid domain -> import ansys geometry -> export to turbogrid(to create mesh) -> setup CFX-Pre -> RESULT
Is it possible to do the FSI simulation by this cfx result?
or I need to import origin cad file into ansys to do the FSI?
Thnak you~
Yining CHEN is offline   Reply With Quote
Old   June 19, 2019, 01:26
Jiri
Jiricbeng is on a distinguished road
it depends if you are talking about 1way or 2way FSI.
1way: just export the results (e.g. pressure) from CFX and apply on the pump structure.
2way: import CAD file into CFX Pre, define FSI and you can initialize the results from your previous analysis. 2way FSI is a very complex analysis, you may encounter many issues and the result may not worth it.
Jiricbeng is offline   Reply With Quote
Old   June 20, 2019, 00:10
Yining CHEN
Thank you so much!
I found some tutorial videos on Youtube about 1way of FSI.
It seems that 1way is easier than 2way!
Thanks for your reply!
Old   June 20, 2019, 11:34
Jiri
1 way is much more easier, in 2 way FSI you would come across many difficulties. SInce you do not have years of experience in CFX I would not recommend 2 way FSI. Go for 1 way.
fsi 2-way coupling, fsi problem, pump, turbo machinery
CFD of a small end suction pump on solid works kliff FloEFD, FloWorks & FloTHERM 0 June 13, 2017 18:44
centrifugal pump Chalghoum CFX 18 April 16, 2014 06:37
Assistance in Vacuum pump simulation enr_venkat CFX 5 November 20, 2012 11:50
Regenerative pump modelled in FLOEFD pro YYY FloEFD, FloWorks & FloTHERM 2 October 5, 2009 05:04
how to extend FSI 2D codes to 3D, need advises abouziar Main CFD Forum 1 May 30, 2008 04:08
