November 11, 2005, 14:06 |
*** Run-time memory configuration error ***
how do I do to solve this error? ------------------------------------------------------------ ERROR #001100279 has occurred in subroutine ErrAction. Message:
*** Run-time memory configuration error *** Not enough free memory is currently available on the system. Could not allocate requested memory - exiting! ----------------------------------------------------------- My computer has 3 Gb of RAM and CFX informs that it will use 2Gb. Regards |
November 11, 2005, 17:39 |
Re: *** Run-time memory configuration error ***
It looks like you've reached the OS limits. I think the OS can only allocate the maximum of 2Gb of RAM for a process (single job). Why don't you try to run in parallel?
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
error while running paraFoam! | padmanathan | OpenFOAM | 9 | October 13, 2009 05:17 |
[Netgen] Installation of Netgen in SuSE Linux 92 | edvardsenpriv | OpenFOAM Meshing & Mesh Conversion | 23 | January 16, 2009 06:12 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
