November 15, 2005, 02:34 |
How to run the CFX-solver in text-mode?
In CFX-10.0 how to run the CFX-solver in text-mode? Could the CFX-10.0 suport "autosave"? thank you very much!
November 15, 2005, 09:13 |
Re: How to run the CFX-solver in text-mode?
Yes it is possible. Open your CFX-10.0 and launch the online help. Type "command line" in the search field and then you can find how to use the solver in the command line mode.
The "autosave" function you're referring can be done with a periodic backup of the run. Just search on "BACKUP RESULTS" within the online help. Good luck! Stevie Wonder |
November 15, 2005, 23:08 |
Thank Stevie Wonder Thank you very much!!
Call for help! Cfx error in Parallel run. | yq11ys | CFX | 5 | November 28, 2022 22:25 |
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 20:02 |
Reynolds Number- CFX Solver | Jwolf | CFX | 5 | January 23, 2010 19:07 |
CFX in queueing batch mode | Matthias1985 | CFX | 2 | June 24, 2009 12:27 |
CFX 5.5 | Roued | CFX | 1 | October 2, 2001 16:49 |
