how to capture boundary layer in cfx
Old   November 17, 2005, 07:59
Default how to capture boundary layer in cfx
michael
Hi to all.I want to capture boundary layer in cfx .I have studied about solver y plus and y plus.But I could not get it properly.I want to know tha thow we can give y plus for BL.i.e. how to calculate that these much no of nodes will be require for capturing B.L.Which equation I should use?
Old   November 30, 2005, 23:35
Default Re: how to capture boundary layer in cfx
rajit
The solver y+ tells you how close is the first node from the wall.generally if u mesh is refined enough then the first node in the boundary layer will be less than 11.
Use the post processor to check this after you create the mesh.
thanx rajit
Old   December 21, 2005, 05:21
Badrinath
One can capture the boundary layer by calculating the rough boundary layer thickness. Then mesh the domain in such a way that you mesh should be fine enough(i.e. resolve). Later check for the y-plus in the post processor of the CFX.
[snappyHexMesh] Boundary layer in a pipe Clementhuon OpenFOAM Meshing & Mesh Conversion 6 March 12, 2012 12:41
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
2D Boundary Layer Development in CFX11 Chris Basciano CFX 1 August 28, 2008 16:15
CREATION OF BOUNDARY LAYER Jibran Haider FLUENT 3 August 1, 2008 00:33
Correct way to generate grids for boundary layer quarkz Main CFD Forum 5 November 23, 2006 23:25
