Does anybody knows how to fix this error in ansys cfx solver? (trcprt) |
June 23, 2019, 21:58 |
Diego Cava
GETCORE stacktrace
1 SU_HYBARR, ,VISCTRB_FL1,ZN1 /VERTICES,LATEST 2 cal_VISC_TRB,LIN-LIN,DENSITY_FL1,BELG8/IP,LATEST 3 cal_VISC_TRB, ,TKE_FL1,BELG8/IP,LATEST Partition: 2 1 SU_HYBARR, ,VISCTRB_FL1,ZN1 /VERTICES,LATEST 2 cal_VISC_TRB,LIN-LIN,DENSITY_FL1,BELG7/IP,LATEST 3 cal_VISC_TRB, ,TKE_FL1,BELG7/IP,LATEST 4 cal_VISC_TRB, ,TEF_FL1,BELG7/IP,LATEST 5 cal_VISC_TRB,LIN-LIN,DENSITY_FL1,BELG13/IP,LATEST 6 cal_VISC_TRB, ,TKE_FL1,BELG13/IP,LATEST +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | Stopped in routine TRCPRT | | | | | | | | | | | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | The ANSYS CFX solver exited with return code 1. | +--------------------------------------------------------------------+ End of solution stage. I HAVE A LAPTOP HP, I7 - 7500U, 16 GB RAM, 2.70 Ghrz |
January 20, 2020, 12:15 |
Amir Seif
Have you figured out this error?
Partition: 35 1 SU_HYBARR, ,VISCTRB_FL1,ZN1 /VERTICES,LATEST 2 cal_VISC_TRB,LIN-LIN,DENSITY_FL1,BELG3/IP,LATEST 3 cal_VISC_TRB, ,TKE_FL1,BELG3/IP,LATEST 4 SU_HYBARR, ,MASCON_MT1_FL1,ZN1 /VERTICES,LATEST 5 SU_HYBARR, ,MASCON_MT8_FL1,ZN1 /VERTICES,LATEST +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | Stopped in routine TRCPRT | | | | | | | | | | | +--------------------------------------------------------------------+ |
January 20, 2020, 13:48 |
Rep Power: 32 |
That is a traceback of an error in the ANSYS CFX Solver when writing some kind of results file.
You may have to contact ANSYS CFX support for guidance, and probably share your setup with them. |
November 21, 2021, 02:44 |
#4 | |
WEI Liangchuan
Rep Power: 4 |
I also encountered the same error, please tell me how you solved it, where is the general error |
November 22, 2021, 10:14 |
Rep Power: 32 |
From the listing, it seems the ANSYS CFX Solver was computing turbulent viscosity and something failed.
You can try using the "Essential" option for results/backup files, and see if the error goes away. If it does, keep in mind you will be missing a few variables in your results file but you will have isolated the issue. Since the calculation is failing, it is possible the written variable may provide a clue to what the source of the problem was. Recall the turbulent viscosity is a function of density, turbulent kinetic energy and/or energy dissipation/eddy frequency depending on the model selected.
cfd, cfx, error #001100279, simulation, solver |
Problem with an old Simulation | FrankW | CFX | 3 | February 8, 2016 04:28 |
Ansys SIG$ILL error | loth | ANSYS | 3 | December 24, 2015 05:31 |
Star cd es-ice solver error | ernarasimman | STAR-CD | 2 | September 12, 2014 00:01 |
Is Ansys CFX the right solver? | Axlex | CFX | 0 | September 11, 2014 11:31 |
Exporting results from CFX to ANSYS ?? | sohail ahmed | CFX | 1 | December 20, 2007 01:10 |
