ANSYS license message
Old   November 11, 2005, 05:21
Default ANSYS license message
Santhosh
I am using CFX 5.7.1 and the license is due to expire in 30days. Hence everytime I open any of CFX products, an ANSYS license message pops up, stating that the license is due to expire in ...days. The application will only start once I hit the OK button. Now I need to use the solver in batch mode and this wont start until I hit the OK button. The first run will go through as I am present, but what about the others when I am not. Any methods to avoid this message apart from getting the new license?
Regards, Santhosh
Old   November 11, 2005, 17:35
Default Re: ANSYS license message
Stevie Wonder
Yeah, these messages occur only in M$-Windows. That might exist (at least it should exist) some environment variable that controls such annoying messages but I'm also interested in that.
S.W.
Old   November 21, 2005, 12:25
tizio
if you have a little experience in programming you can build a small program that periodically looks for Ansys license popup windows and sends them a closure message (you just have to set a timer and to check the names of open windows). Since I don't have Administrator privileges on my computer, I couldn't find an easier way to get rid of those messages.
I hope you'll find it useful...
ciao
Old   November 22, 2005, 00:25
Santhosh
Thanks,
This problem was solved with the help of Tech Support, just need to add an environment variable and that would get you through to 7 days before the license expires.
Santhosh
Old   November 22, 2005, 06:57
Stevie Wonder
And would you share this environment variable with us?
S.W.
Old   November 23, 2005, 05:54
Santhosh
Its,
ANS_FLEXLM_EXPWARN_DAYS = 'days'
Santhosh
Gambit and Fluent license error message Dimitris FLUENT 11 October 1, 2012 02:05
License Error lffabiani CFX 2 June 30, 2011 20:51
ANSYS License Error vincentryan.s ANSYS 0 June 7, 2011 15:31
installing ansys license mr_aliagha ANSYS 3 December 23, 2010 11:21
ansys 12.1 license error clarkent ANSYS 5 November 1, 2010 08:48
