How to store transient data with various timestep?
Old   December 15, 2005, 23:33
Default How to store transient data with various timestep?
Oliver
I've a problem storing transient data. I run the transient simulation from 0 to 10 second with time step of 0.00001 second but I only want to save data as follows:
1) from 0 to 1 second with 0.0001second time intervals
2) from 1 to 2 second with 0.001second time intervals
3) from 2 to 3 second with 0.1 second time intervals
4) from 3 to 10 second with 1 second time intervals
How can I specify time intervals in Pre (under Output Control menu)? I've both 5.7.1 and 10 at different machines.
In 5.7.1, I can either select a fixed time intervals or put a time list....However, I have different time intervals here. Inserting 1000+++ time value in the time list is exhuasting....Any better way of doing this? If it's not possible, please also let me know....
Thanks for your help. Oliver.
Old   December 16, 2005, 07:24
Default Re: How to store transient data with various times
Rui
As far as I know it isn't possible. The only way I see to do that is by creating 4 different simulations, and starting simulation 2 with the .res file from simulation 1, and so on.
Regards,
Rui
Old   December 16, 2005, 17:01
Jianping
Hi, Oliver
If you input 10000*0.0001, 1000*0.001, 10*0.1, 7*1 as your time step, you should be able to get what you want.
Regards!
Jianping
Old   December 18, 2005, 19:29
Oliver
"If you input 10000*0.0001, 1000*0.001, 10*0.1, 7*1 as your time step, you should be able to get what you want."
Thanks for your help but how could the solver know the time when the time step start to change if you specify this way?
e.g. 1000*0.001 time interval is supposed to start at t=1 second while 7*1 time interval will start at t=3second....
Old   December 18, 2005, 19:56
Jianping
If you feel confused about this, you can simply test it by run a case with time step as '2*0.1, 2*1'.
Regards!
Jianping
How to extract data from a completed transient run Vince CFX 3 November 26, 2019 05:59
[OpenFOAM] No data for timestep solutions bouke ParaView 8 June 12, 2007 10:06
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 17:27
Loading transient data of moving grid leo Siemens 3 April 9, 2003 01:35
Writing a transient data fileld ant CFX 0 October 20, 2002 12:19
