Streamline does not appear from the interface |
July 30, 2019, 10:37 |
Overijssel
Rep Power: 7 |
I am designing a pump blade. While calculating the performance of the centrifugal impeller, I do not see the streamlines from the rotor-volute interface. I thought that the streamline of the whole rotor-volute domain could be visualized when I selected the streamline to start from the Inlet. But, it stops in the interface. The solution is converged and the head and efficiency criteria are met but I wanted to see the overall flow from inlet to outlet to map the turbulent regions. Is it because I have a huge gap (50 mm) at the rotor-volute interface? The interface is frozen rotor with pitch change set to automatic. Thanking you. Suman |
July 30, 2019, 10:50 |
Abdullah Arslan
Rep Power: 7 |
Hi
it seems like some of your domain are switched off. Anyway, try just for inlet pipe domain then go to all domain. |
July 30, 2019, 21:20 |
Rep Power: 144 |
Are you sure your interface is working correctly? Your 50mm gap does not sound good. Look in the output file at the report on interfaces and see if you have a large non-overlap region. Also, in the post-processor look at the non-overlap variable which shows where your interfaces are not joined.
I suspect your interface is not connecting because of the big gap.
July 31, 2019, 04:32 |
Problem Solved
Overijssel
Rep Power: 7 |
Thank you Goenitz. The problem was not in the domain.
Thank you Ghorrocks. Like we speculated, the problem was in the Gap. Keeping the gap at 1 mm did the trick. |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 05:15 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
