convective + radiative heat transfer coefficient boundary condition |
August 12, 2019, 07:01 |
Rep Power: 8 |
Is there any not so complicated way how could I write an expression that would estimate overall heta transfer coefficient (both for radiation and convection) according to boundary surface temp? If it is too complicated I could be satisfied only with radiative htc. I can estimate that convective htc for my simulation is somewhere between 5-10 W/m2K but I would like to sum it with htc for radiation and put it inside boundary condition as heat transfer coefficient. How could I do that? I am using cfx for the simulations Thanks |
August 12, 2019, 08:06 |
Rep Power: 8 |
Ok so for the radiative htc I did something like this 5.67e-08[W m^-2 K^-4]*Temperature^3*Emissivity+8[W m^-2 K^-1]. I think thats it. The problem is if I would like to be more precise with the htc for natural convection I would have to calculate Grashof number and for that I need characteristic length for either vertical or horizontal plane. I think I am not able to get this value in cfx expression because something like MaxVal(y)@meshregion - MinVal(y)@meshregion doesn't work.
I would be also interested in knowing how other calculate models that are larger and heat from surfaces is lost to the ambient. Do you just use air enclosure with buyoancy turned on and let ansys do the natural convection calculation? This is not option for me because I use large and rather complicated models. |
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 01:13 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
convective Heat transfer coefficient at a reference temperature as boundary condition | jayaraj | OpenFOAM | 0 | July 20, 2012 07:41 |
Enforce bounds error with heat loss boundary condition at solid walls | Chander | CFX | 2 | May 1, 2012 20:11 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
