September 23, 2019, 08:02 |
averaging on flow field
Zese
Rep Power: 12 |
Dear Friends
I simulated a flow inside a diverging pipe and I want to average my velocity field in azimuthal direction (Theta) to have axisymmetric flow field on a 2D plane. I thought that defining several plane inside the pipe with 30 degree difference may help but the number of nodes in each plane is different. do you know what can I do? or do you know which additional software would do that for me? Thanks very much |
September 23, 2019, 18:33 |
Rep Power: 143 |
You could export the data and do it outside CFX (eg matlab, python etc).
But I do not know why you are doing this, what output you want or what you mean by planes with 30 degree difference and why different number of nodes is relevant.
September 24, 2019, 04:44 |
#3 | |
Zese
Rep Power: 12 |
1. I exported data in 3D and imported to MATLAB; then I tried to fitt a function the velocities and take an integral in theta direction which was unsuccessful 2. In CFD post I considered 8 plane with 45 degree difference in theta direction and exported velocity fields on these plane and avaraged between them. I am not sure if this method is right or not. |
September 24, 2019, 18:55 |
Rep Power: 143 |
This should be straight forward in matlab/python from a 3D data export from CFD-Post. So check your maths in matlab.
Averaging a velocity field (SW flow simulation) | joaopffg | FloEFD, FloWorks & FloTHERM | 14 | August 25, 2017 03:23 |
MHD and existing flow field | sina_mech | FLUENT | 1 | March 22, 2015 19:18 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
rerun with same flow field, different fluid props | Tim | Phoenics | 0 | March 3, 2004 14:51 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 21:31 |
