A quick question for CFX-mesh 9.0
Old   January 31, 2006, 13:14
Default A quick question for CFX-mesh 9.0
Forrest
Hi all,
From the tree view of CFX-Mesh 9.0, the option of 'Inflation' is available for use. It's ok when I inflate a number of surfaces in one go, but it seems I am not able to distinguish these surfaces. For example, I want 5 layers for 1 surface and 10 layers for other surfaces I want to inflate, I just can't do it. When I 'insert' inflation boundaries, I can only select locations. It seems that I can 'insert' different inflation boundaries (at different locations/surfaces), but only one set of 'inflation' parameters are applied to all the inflation boundaries. Anyone can give me some highlights about this?
Thanks a lot, Regards
Forrest
Old   January 31, 2006, 14:04
Default Re: A quick question for CFX-mesh 9.0
longbow
Unfortunately, the feature you are looking for is not even in CFX-Mesh 10. I doubt it will show up in CFX-Mesh 11.
Old   January 31, 2006, 14:08
Forrest
oops! Thank you very much, longbow, so I should stop wondering then. Cheers, Forrest
Old   January 31, 2006, 17:22
You can do this using ICEM. If you have the advanced meshing option give that a try.
Old   January 31, 2006, 17:53
longbow
It may not be a bad idea to make a request to CFX. The more requests they get, the better chance they will implement it.
Old   February 1, 2006, 04:39
Forrest
Hi Glenn, Thanks for your comments. I do have ICEM CFD 5.0 available for use. I was suggested to generate a surface mesh and then extrude it one cell for the third direction. But when I generate the surface mesh I am not able to add inflation for it. Also the 2D domain I am modelling includes multiple fluid-solid domains, and the ratio of the largest edge and teh smallest edge can be over 8000, the curvatures are very difficult to manage when I try to mesh it use blocking. By the way, if I do use the advanced option for Mesh Prisms, is it possible to add it onto a surface mesh, then I extrude it?
Thanks again, Forrest
Old   February 1, 2006, 16:31
You will need to be very careful meshing a geometry with such large geometry scales. I recommend you do plenty of examples to get confident with the mesher before attempting this geometry.
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
[ICEM] Unstructure Meshing Around Imported Plot3D Structured Mesh ICEM kawamatt2 ANSYS Meshing & Geometry 17 December 20, 2011 11:45
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
a mesh motion question womo CFX 5 March 16, 2011 10:54
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 10:09
