Is it possible to apply a Fixed temperature to a Volume of air in CFX? |
October 9, 2019, 14:31 |
Aja
Rep Power: 14 |
Is it possible to apply a Fixed temperature to a Volume of air in CFX? I am simulating a problem that air is around a material and this air(volume) have a Fixed temperature in this problem. In fact, the material temperature rise because of this hot air volume . Thanks. |
October 9, 2019, 14:33 |
Rep Power: 32 |
You can make a domain isothermal, i.e., set the heat transfer model to isothermal
October 9, 2019, 14:39 |
Erik
Rep Power: 23 |
Yes, that is called a Dirichlet boundary condition. But it doesn't sound like a realistic setup to me.
You would apply a volumetric heat source (subdomain) that is a function of local temperature and intended temperature. Cp * Density *(T.intended - T)/1[s] with a source term coefficient of -1[s]. Again, this does not sound realistic if you are intending to simulate heat transfer. |
October 9, 2019, 15:06 |
#4 | |
Aja
Rep Power: 14 |
In within this mentioned material, there is another volume air then I should apply energy equation because I want to see temperature variation in this material and the existence air in material. |
October 9, 2019, 15:11 |
#5 | |
Aja
Rep Power: 14 |
Thanks. could you please explain more? what is a source term coefficient of -1[s]? where I should use this in CFX? source coefficient is in w/m^3K in CFX not [s]. |
October 9, 2019, 15:15 |
Aja
Rep Power: 14 |
Air in Material have a initial temperature in this problem but air around the material have a Fixed temperature.
October 9, 2019, 16:02 |
Gert-Jan
Rep Power: 27 |
You can do this in Fluent. It has the functionaity to set the temperature in a certain volume to a fixed value. And if something flows through it, it gets that temperature.
It is realistic? Don't think so. But it can be useful. I used it to model the flow through a burner without taking the complete combustion process into account. I just wanted the temperature rise....... |
October 10, 2019, 11:00 |
#8 | |
Erik
Rep Power: 23 |
Just make it negative 1[s^-1]*(whatever units it wants to be correct). If your function will change the temperature from local to Intended in 1 second. It just linearizes the source term to make it more numerically stable. It should be around equal to the derivative of the functions effect for the best stability I believe. See the documentation for more details. If you don't use source term linearization, you can't use a timestep larger than your source terms effect time, or you will get overshoot and numerical instability. |
[openSmoke] libOpenSMOKE | Tobi | OpenFOAM Community Contributions | 562 | January 25, 2023 09:21 |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
CFX CHT increased mass flow rate for water matters little for outlet air temperature | dingsheng1206 | CFX | 7 | December 4, 2013 20:04 |
How to apply negtive pressure to outlet | bioman66 | CFX | 5 | June 3, 2006 01:40 |
