September 29, 2015, 22:02 |
Temperature overshoot
Hazel James P. Agngarayngay
I have successfully run my simulation (convection-conduction problem). I thought it was running smoothly. However, I noticed that the temperature of the test material continues to increase linearly, even exceeding the temperature of the medium. The temperature of the medium is set at a constant temperature of 328K and a heat transfer coefficient of 30W/m^2.K. The initial temperature of the test material is 298K.
I put 'monitor points' in the test material to observe the temperature change on that particular point over time. After a 1-hour (total time) transient run, the temperature at the monitor points have reached up to 346K, way higher than the maximum temperature set for the run. What could have been the problem? Every advice is highly appreciated. |
September 30, 2015, 13:38 |
Rep Power: 32 |
Your description of the model is incomplete.. You should describe all your boundary conditions to determine if the system is bounded or not.
September 30, 2015, 17:54 |
Rep Power: 143 |
Please post your CCL and an image of what you are modelling.
convection-conduction, temperature overshoot, transient run in cfx |
Shadow Wall and temperature | norger | FLUENT | 10 | September 28, 2019 11:43 |
UDF for Back-flow Temperature | G340 | Fluent UDF and Scheme Programming | 3 | August 21, 2013 04:56 |
How to get free stream temperature in boundary condition | saharesobh | FLUENT | 0 | October 9, 2012 17:12 |
where is the calculation of the temperature field | Tobi | OpenFOAM | 1 | July 30, 2012 10:40 |
monitoring point of total temperature | rogbrito | FLUENT | 0 | June 21, 2009 17:31 |
