ACOUSTICS FOR TURBOMACHINERY
Old   February 9, 2006, 22:13
Default ACOUSTICS FOR TURBOMACHINERY
Badrinath
Hi, I am currently having a problem in evaluating the aero noise level and how I can use the CFX xoftware to my problem.
I have designed an axial blower and I have performed the normal analysis and I got pretty good results which I can validate with the test results. But at the same I need to simulate the aero noise level prediction which i need to meet the experimental values. So please get me how I can use CFX in my case.
Old   February 10, 2006, 10:52
Default Re: ACOUSTICS FOR TURBOMACHINERY
longbow
This depends on your needs. Do you want to calculate tone or broadband noise? Do you compare near- or far-field noise? To estimate blade tone, an URANS may be enough. However, for broadband noise, if you want to get it from first-principle approach, you'd better go with LES or DES. All those options are available in CFX.
Old   February 10, 2006, 21:01
Badrinath
Hi Longbow, I want to calculate only near field noise and I hav etried this option whih you have explained but still I am not able to match with the test results where I am able to match the same with other softwares. How I can fully utilise the CFX software for this pparticuly problem.
Regards Badri
urgent!!! surface dpdt values in acoustics samad87 FLUENT 0 August 31, 2009 23:53
How to solve acoustics ? wolle1982 OpenFOAM Running, Solving & CFD 8 May 18, 2009 04:20
Unsteady modelling - AMG divergence + acoustics Neville FLUENT 0 September 3, 2004 00:21
Acoustics in Fluent Nurul Murad FLUENT 0 April 1, 2004 22:11
Acoustics Problems and Fluent Dezfuli FLUENT 1 February 10, 2002 15:59
