Modeling
Old   March 4, 2006, 15:16
Default Modeling
Ruchi
I have a geometry with a 'main' inlet and two 'side' inlets, an outlet and 2 vents. The 'main' inlet is held at a pressure of 1000 Pa. The two 'side' inlets are at pressure of P1 and P2. The vents are open to atmosphere. I want to plot my outlet pressure vs P1 and P2. But I know nothing about my outlet BCs. I couldn't calculate the mass flow rate through my outlet because of the complicated geometry. Can anyone help me with this issue?
And I also don't understand if I have applied a pressure of 1000 Pa, but I observed pressures of upto 10^5 Pa in post-processing. And some negative presure values also. Can anyone explain to me what does that mean or why is that so?
Thanks, Ruchi
Old   March 6, 2006, 07:59
Default Re: Modeling
siv
Did you specify pressure values with respect to default reference pressure of 1 atm?
May Focus Area: Turbulence Modeling Jonas Larsson CFD-Wiki 0 May 2, 2006 11:48
Modeling Flow/Saturation/Absorption in Fibers Gene Dougherty Main CFD Forum 0 June 6, 2003 14:49
Solid Modeling Chris Main CFD Forum 10 July 2, 2002 07:12
CFD Modeling of Two-phase Flow in Small Dia.Tubes Eric Poindexter Main CFD Forum 2 September 22, 2000 09:21
Extrusion Modeling Elliot Schwartz Main CFD Forum 1 September 11, 1998 19:08
