Unexpected flow angle
Old   January 1, 2020, 04:20
Default Unexpected flow angle
Julian121 is on a distinguished road
I would like to plot relative velocity angle versus span normalized at some location upstream of the leading edge.
I noticed when I use mass, length and area averaging the angles at this location change significantly.
Unexpectedly, I get different angles at shroud as follows:
length averaging: 88 deg
area averaging: 159 deg
mass averaging: 163 deg
Please note the angles at the shroud location in the attached images (span normalized: 1).
When I measure the angle using a probe in the tip it shows around 170 degrees.
Does anyone know why length averaging produce a wrong result?
Also, when I increase the number of samples the angle at the shroud keep increasing.
Julian121 is offline   Reply With Quote
Old   January 2, 2020, 01:04
I mean which one of the length, area or mass averaging is more appropriate for velocity flow angle?
Match Pressure Inlet/Outlet Boundary Condition Mass Flow Rate MSchneid Fluent UDF and Scheme Programming 3 February 23, 2019 06:00
Flow Angle Specification Nikhil008 STAR-CCM+ 1 June 13, 2018 09:00
Inclination angle and counter current flow Prabha FLUENT 3 April 11, 2011 21:00
modelling inviscid 2D flow at high angle of attack Ferdinando FLUENT 2 October 30, 2007 17:26
angle for wall adhesion in two phase flow Al-jasim FLUENT 0 August 18, 2007 10:04
