patching the outlet to the inlet
Old   March 9, 2006, 03:17
Default patching the outlet to the inlet
laxminarayan
hi in my problem i have to circulate a portion of the outlet flow to the inlet. how this can be done.
Old   March 10, 2006, 05:51
Default Re: patching the outlet to the inlet
ms
Try using a periodic domain interface. Good luck
Old   March 10, 2006, 06:46
laxminarayan
hi
my problem in cfx is to circulate a portion of the outlet. here as u said if i use periodic it will circulate every thing and also the geometry and the grids are different for both the inlet and outlet. so, i cant use that. Is there any other method.
Old   March 10, 2006, 13:38
Robin
I assume there is stuff happening in between on the return path, so is it that you want to make your inlet a function of the flow at the outlet? If that is the case, you can do so by using CEL expressions relating the two.
-Robin
Old   March 10, 2006, 23:47
sumanth
we are (laxmi and suamnth) trying that one but the mass fraction value i am struct up with. i am trying to get the mass fraction values at the outlet. how express the mass fraction? thank you for ur valuble suggestions. we will be trying. bye
Old   March 13, 2006, 11:34
Robin
Hi Sumanth,
The actual variable name will depend on the fluid name, it ends up being something like <component>.mf. Have a look at your variable names in Post to know for sure.
Regards, Robin
Old   March 15, 2006, 06:49
sumanth
thank you robin, we got some recirculation, we did it for a single fluid. now we want to do that for particle also we are not able to track the particle in our case we took a varible composition mixture coal consisting of volatiles, char and ash. now we have to find the conditions (mass fractions of volatiles, char and ash) what you told .mf is working fine for fluid(continues). i cant get the numerical values of the particles. sorry for my late reply. bye
Mapping outlet patch to inlet patch of new case val46 OpenFOAM 0 February 18, 2011 11:22
Boundary conditions: inlet and outlet aline OpenFOAM 7 June 29, 2010 03:45
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 15:45
Duct Flow with 90 degree inlet and outlet k FLUENT 3 August 19, 2007 14:30
how to set inlet and outlet? green Phoenics 5 May 18, 2004 23:52
