Who stole my Yplus?
Old   March 15, 2006, 13:32
Default Who stole my Yplus?
Chebeba
There is a whole bunch of references to the Yplus variable which is supposed to be defined on wall regions.
Only I have no Yplus in my variables list
There must be something I'm doing that causes it not to be saved in the result file or something???
The simulation is free surface homogenous multiphase static domain with SST turbulence model. My mesh has extrior walls with free slip, inlet and outlet. The hull is a no-slip wall boundary with 20 prism layers.
When I make the hull region color variable there is no Yplus variable in the "..." list. Neither is there any Yplus in the tree under the "Variables" tab. The FAQ says "Yplus will appear in the list of variables which are loaded into ANSYS CFX-Post, if it is appropriate for your calculation."
Only it doesn't say what makes it "appropriate"???
/C
Old   March 15, 2006, 14:51
Default Re: Who stole my Yplus?
opaque
Dear Chebeba,
I would call the CFX help desk, and check if there was a bug where Y+ was not being written for homogeneous multiphase..
I seems to recall/read something like that for 10.0 SP1..
Good luck, Opaque
Old   March 18, 2006, 13:19
Jeff
a) the simulation must be turbulent, or there will be no Y+ calculated.
b) The Y+ value is not in the abreviated drop down list. You have to go to the extended list ( the [...] button ) to get to some of the advanced usage variables.
Jeff
Old   March 19, 2006, 05:24
TB
Jeff,
When you choose "full" output option, Y+ will normally include in the list.
Old   March 23, 2006, 04:18
Chebeba
This was a 10.0 bug, it works fine in SP1. /C
How to calculate Y+( Yplus) mohammad Main CFD Forum 3 January 11, 2011 23:23
which yplus (SST) sanchezz CFX 17 January 11, 2010 04:45
Who stole my YPlus! Usman CFX 6 October 26, 2007 08:33
X-Y plot of Yplus in Fluent 5.3 Luo FLUENT 24 April 11, 2000 06:07
heat transfer coefficients with "bad" yplus Andrew Main CFD Forum 4 April 8, 1999 04:43
