BC setting
Old   March 18, 2006, 09:13
Default BC setting
Richard
Hi, what the different of setting average pressure for inlet and mass flow rate for outlet,with mass flow inlet & pressure outlet
Old   March 20, 2006, 10:49
Default Re: BC setting
steve
Hi richard!! If u use a mass flow rate at the outlet, you enforce the fluid to go out of your domain with a normal direction. If you use a pressure at the outlet, then your fluid are not going to be enforced to go out normally to the boundary limit. The BC could modify the velocity upstream the outlet.
steve
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 21:58
Sover setting with TUI junbbung FLUENT 0 August 20, 2009 00:43
LiftDrag utility from v12 to v141 cfdphil OpenFOAM Running, Solving & CFD 2 December 5, 2007 05:49
Ultra high temperature? bk Siemens 2 July 19, 2005 00:01
Warning 097- AB Siemens 6 November 15, 2004 04:41
