Hi, I am modeling a pipe flow containing a restrictor. A thin gap with about 0.1 mm hight occurs. My question is what should be the minimum amount of elements in this gap regarding hight) for good results with sst?
greets |
There is no general answer to that question as it depends on the flow, geometry and lots of other things. Do a mesh refinement study on it and find out. Glenn Horrocks |
Ey thx I am trying. Leads me to the next problem. Refining the mesh leads the mesh to creep out of the body at narrow overlapping surfaces. Possible to avoid that?
In ICEM have a look at thin cuts (I think that is what they are called). CFX-Mesh should not have this problem. Glenn Horrocks |
Reversed flow error with thin film heater | MK | FLUENT | 1 | February 12, 2009 10:26 |
ICEMCFD - Prisms in a gap | Andreas | CFX | 1 | January 18, 2009 18:24 |
Thin surfaces within a body using DesignModeler? | Forrest | CFX | 7 | April 5, 2005 08:21 |
Meshing thin surfaces | Louwrens | CFX | 8 | August 18, 2003 17:49 |
Modelling thin surfaces in 5.6 | Louwrens | CFX | 0 | August 16, 2003 10:47 |
