about CFX solver
Old   April 6, 2006, 05:31
Default about CFX solver
student
Dear all, I have generated a mesh and set the conditions in the CFX-Pre, but when i run the CFX-solver, the following message appear: "ERROR #004100018 has occurred in subroutine FINMES. | Message: Fatal overflow in linear solver." Does anyone know what that mean? Can you explain that for me, please? Thank you
Old   April 6, 2006, 06:31
Default Re: about CFX solver
Quest
You set bad boundary conditions and/or initial conditions. the linear solver is unable to find a linear solution with it. You must set these conditions more careful and/ or decrease the timesteps for the first (about) 20 iterations.
Old   April 6, 2006, 06:32
cfd worker
first check that u have taken right model.if yes then there may be problem with ur mesh.so improve ur mesh.
Old   April 6, 2006, 19:02
The dreaded FINMES error means your simulation has diverged big-time. Have a look in the documentation about obtaining convergence.
Quest and cfd worker correctly point out that the problem can be caused by incorrectly defining the simulation, but it can also be caused by an excessively large timestep, unstable physics of lots of other reasons.
Regards, Glenn Horrocks
Error message CFX Solver Fatnes CFX 25 July 3, 2015 10:32
CFX SOLVER error !!! mehrdadeng CFX 3 November 23, 2009 16:42
mach number and CFX 11.0 solver turbinesv CFX 5 January 5, 2009 05:43
CFX Solver to run 10 files sequentially Raj CFX 8 October 29, 2008 22:20
problem in CFX solver about isolated volumes Yuan CFX 2 August 16, 2004 22:54
