February 12, 2020, 11:18 |
Alternate rotation method
Sai Paruchuri
Rep Power: 6 |
I am simulating flow through an axial pump (by specifying total pressure at inlet and static pressure at outlet), so bulk of the flow is moving in the axial direction. I observe some spurious vectors in the blade tip gap and swirl at the interface between rotating and stationary domain. Also the flow rate is much less than measured value. For a coarse mesh, when I turned on the alternate rotation method, it seemed to correct the flow vectors and the flow rate value. However, with a fine mesh, the swirl continues to exist and the simulation gives a low flow rate despite turning on the alternate rot method. Kindly help me understand what's happening!
February 12, 2020, 12:38 |
Gert-Jan
Rep Power: 27 |
We need a screendump to really make a good comment.
However, a mistake people quite often make is that they judge this kind of simulation by looking at the vectors and flow with variable "Velocity". I suggest to look at "Velocity at Stn Frame" Last edited by Gert-Jan; February 12, 2020 at 15:27. |
Method similar to MRF for Fan rotation | arulnambi_palani | Main CFD Forum | 0 | July 19, 2019 04:18 |
Vortex Panel Method | Rafaelle55 | Main CFD Forum | 1 | December 17, 2018 10:16 |
On the alpha Eqn of VOF method when using Immersed boundary method in OpenFOAM | keepfit | OpenFOAM | 4 | January 31, 2014 14:32 |
multiphaseEulerFoam: method mag(...) withing method solveAlphase() | maybee | OpenFOAM Programming & Development | 0 | December 21, 2013 10:13 |
Help about the preconditioner in gmres method | Dan Gao | Main CFD Forum | 3 | July 5, 2008 01:18 |
