July 6, 2023, 08:24 |
Using user function variables in expressions
Rep Power: 2 |
I am trying to model a stent in a blood vessel as a type of porous media. To do this, instead of a 3D porous domain, I am attempting to use a 2D interface with a pressure change as defined in the theory documentation. This seems simple enough with constant Kloss and Kperm coefficients but my aim is to have them vary over the stent to represent a heterogenous interface. As far as I can work out, this should be doable with User Functions and Expressions. Essentially, I have imported spatial data with a Kloss and Kperm variable as an interpolation function (which appear on the right place of my mesh), and have tried to include them in an expression for the pressure change dP. Unfortuantely, I cannot get this to work I get the error message 'Bad expression value 'dP' detetcted in parameter 'Pressure Change' in object '/FLOW:Flow Analysis 1/DOMAIN INTERFACE:STENT/INTERFACE MODELS/MASS AND MOMENTUM/MOMENTUM INTERFACE MODEL'. CEL error: The following unrecognised names were referenced: Kloss.Kloss, Kperm.Kperm. It feels like their should be a simple fix but I can't for the life of me figure out, any help would be much appreciated. |
July 6, 2023, 19:42 |
Rep Power: 143 |
It says it is just a CEL error, which means you syntax is wrong. Please attach your CCL or output file.
cel, interfaces, porous media, user functions |
whats the cause of error? | immortality | OpenFOAM Running, Solving & CFD | 13 | March 24, 2021 07:15 |
[blockMesh] Errors during blockMesh meshing | Madeleine P. Vincent | OpenFOAM Meshing & Mesh Conversion | 51 | May 30, 2016 10:51 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 05:42 |
is internalField(U) equivalent to zeroGradient? | immortality | OpenFOAM Running, Solving & CFD | 7 | March 29, 2013 01:27 |
User field function for specific heat deifnition | crevoise | STAR-CCM+ | 2 | January 28, 2013 04:25 |
