problem with probe
Old   May 17, 2006, 06:27
Default problem with probe
Yolanda
Hi again!
I haven't solved all my problems yet. I have an inlet whose velocity depends on a routine (H2On) that is going to be:
1 = input on
0 = input off
like that --> expressions:
VelocityY = H2On*10 [m s^-1]
H2On = Sensor Function(CSensor,CLim,aitern)
CSensor = probe(Mixture.H2 Ideal Gas.Mass Fraction)@Detector
where Detector is a monitor point and CLim is a constant.
The message I've got is:
The function 'probe' referenced in parameter 'V' in object '/FLOW/DOMAIN:Room/BOUNDARY:InletH2/BOUNDARY CONDITIONS/MASS AND MOMENTUM' has an invalid argument, 'Mixture.H2 Ideal Gas.Mass Fraction'. The prefixed variable is not valid in the context of the locator 'Detector'.
Where's the problem? Syntaxis? The routine? It's very similar to the tutorial 17 (Air Conditioning) but it doesn't work. Thank you!
area does not match neighbour by ... % -- possible face ordering problem St.Pacholak OpenFOAM 10 February 7, 2024 21:50
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
