May 30, 2006, 05:31 |
Fatal overflow in linear solver error. Why?
| ERROR #004100018 has occurred in subroutine FINMES. | | Message: | | Fatal overflow in linear solver.
hi i run my analysis using k-epsilon turbulence model and after 9 iterations, above error ocuured. i mesh my model in Gambit and using boundary layer as follows; -first layer thickness = 0.0001 m -expnasion factor = 1.2 -layer = 20 layer can anybody give me an idea.. |
May 30, 2006, 18:20 |
Re: Fatal overflow in linear solver error. Why?
Your simulation has diverged. Look in the documentation under obtaining convergence. Glenn Horrocks |
June 1, 2006, 00:31 |
this problem happened again to me!Is there any BC not apprcieate for me???i set pressure for inlet,and pressure for outlet ,is it allowed???
June 9, 2006, 09:12 |
As a quick fix: Did you try adjusting your timestep from automatic to manual?
Divide the recommended auto time step by 10^3 and try it again. |
August 10, 2016, 08:25 |
Brett
Great response Glenn,
Could you perhaps elaborate on what the physical timescale does? I am aiming to run a steady flow simulation, what effect does it have in this case? Cheers (Fellow Australian I see) Brett |
August 10, 2016, 19:25 |
Rep Power: 143 |
Hi Brett,
You certainly have dug up a thread from ancient history here. You are lucky that I am still around I have not seen the other people on this thread for 10 years.... Physical time scale is the rate at which CFX advances the numerical values in a steady state simulation. There are other ways of doing it used in other software such as under-relaxation, but CFX does it by a physical time scale. So a large time scale advances the values a large amount, a small time scale advances it a small amount. Large time scales can approach convergence quicker, but you can only go so fast before the numerics becomes unstable and the simulation diverges. Note that the physical time scale in a steady state simulation is not the same as time step size in a transient simulation. A steady state simulation has many transient terms removed as they are zero for steady state, whereas a transient simulation includes all the transient terms. |
August 11, 2016, 04:26 |
Brett
Thanks Glenn, Lucky indeed.
How does that related to the mesh density, ie the dx,dy,dz values? Is it the increment it adds on from the initial values at each cell? Brett |
August 11, 2016, 05:59 |
Rep Power: 143 |
Have a look at the CFX documentation and a CFD textbook for an answer to that question. The spatial discretisation is handled very differently to the time discretisation (for a transient simulation) or the convergence advancement procedure (for a steady state run). I will not describe the difference on the forum as it is far too complex. Hence see a textbook.
Fatal Overflow when using RNG k-e | Pascal | CFX | 2 | February 5, 2008 16:41 |
free C code for large sparse matrix linear solver | ztdep | Main CFD Forum | 7 | May 24, 2007 14:14 |
Solver: Fatal Bounds error detected | hagupta | CFX | 5 | March 24, 2006 10:17 |
linear solver overflow | peggy | CFX | 1 | February 8, 2001 01:39 |
solver for linear system with large sparse matrix | Yangang Bao | Main CFD Forum | 1 | October 25, 1999 04:22 |
