" ****** Notice ******"-----what it mean???
Old   May 31, 2006, 21:27
Default " ****** Notice ******"-----what it mean???
prayskyer
Wall Heat Transfer Coefficient written to the results file uses "Wall Adjacent Temperature" for the bulk temperature. If you want to override the bulk temperature then set the expert parameter "tbulk for heat tran coef = <value>"
when i start a computation, which is come out,why it come out?
Old   June 5, 2006, 02:15
Default Re: " ****** Notice ******"-----what it mean???
prayskyer
i still concern on this!!!
thanks a lot!!!
Old   June 5, 2006, 11:50
Robin
It means that the variable "Wall Heat Transfer Coefficient" written to the results file uses the "Wall Adjacent Temperature" (i.e. the conservative value of temperature of the control volume next to the wall) for the bulk temperature. You can override this behavior and use a single bulk temperature for the HTC, then set the expert parameter "tbulk for heat tran coef = value", where the value is the desired temperature in the solver units (usually Kelvin, unless otherwise specified).
CFX 12.1 Notice Roland R CFX 1 March 10, 2011 13:17
can any body give me an answer about the notice wwwuxing Main CFD Forum 2 December 25, 2010 22:55
Notice A wall has been placed at portion (s) of an OUTLET nuimlabib Main CFD Forum 0 July 17, 2010 13:30
Help me please. Notice in Pre-solver Eric CFX 1 June 6, 2006 05:34
Solver notice. Ted CFX 3 April 19, 2005 09:53
