Create 2D hexa block from points
Old   June 22, 2006, 07:31
Default Create 2D hexa block from points
alexey
I want to create 2D hexa block from 4 geometric points. I can use for same purposes: Create Block -> 2D Surface Blocking, but this comand create blocks automaticaly (usually it operate very bad). I want to do it manually. I can do it for 3D, but for 2D i get error "Current blocking is 3D"
Old   June 22, 2006, 07:49
Default Re: Create 2D hexa block from points
myron
Try
Initialize Blocks > 2D Planar instead of 2D Surface Blocking.
You could also use Create Blocks > From Vertices. Once in selection hit middle-mouse to select the 4 geometry points (in a Z - fashion) rather than existing block vertices.
[ICEM] Hexa to Sweep block conversion pertupd ANSYS Meshing & Geometry 1 June 19, 2010 21:37
Where's the singularity/mesh flaw? audrich FLUENT 3 August 4, 2009 01:07
journal file to create points simona FLUENT 1 May 29, 2008 01:27
Hybrid hexa block F.K. CFX 4 January 13, 2005 06:49
