Fluent and CFX to share the same licensing manager
Old   June 25, 2006, 10:56
Default Fluent and CFX to share the same licensing manager
Roger of Canada
Hello
Ansys Sales guy told me that ansys, fluent and cfx will share the same licensing scheme So you can install both software and each will look into into the same pot for avaialable licenses.
They say support engineer are not happy as they will have to learn both code and be able to support both.
What do you think of this arrangement?
Thank you,
Roger
Old   June 25, 2006, 17:33
Default Re: Fluent and CFX to share the same licensing man
ANSYS uses flexlm. I have no idea what Fluent uses, but flexlm is very common across the industry and I would not be surprised if it uses flexlm also. If Fluent already uses flexlm then they already share the same license manager, if not then it makes sense to shift across to flexlm. Flexlm is a industry leader in software licensing utilities.
Sounds like a sensible move to me.
Old   June 25, 2006, 19:51
Robin
While this is plausible, nothing of the sort has been planned. You may have misinterpreted what your sales rep told you. As for support, it isn't much of a problem; where necessary, CFX support would go to CFX people and Fluent support to Fluent people. Over time, there would be knowledge gained by staff on both codes and more resources could be shared. Most support questions relate to 'how' to model something anyhow and are really code independant.
-Robin
Old   June 26, 2006, 03:07
deLuther
As I know Fluent also uses FlexLM. I think ANSYS should switch from fluent licensing daemon to common ansys daemon like it was for CFX or ICEM.
Old   June 28, 2006, 13:50
Astrid
I would strongly encourage this merge. We have 4 CFX licenses and 1 Fluent. For particular situations it would be very convenient to use a CFX license for a Fluent run.....
Astrid
Old   June 28, 2006, 14:55
Mike
Sharing the same License Manager is not the same as sharing license keys! While is seems probable that the ANSYS License Manager can be used to administer CFX, Fluent, ICEM and ANSYS license keys, it does not mean that a CFX license key would suddenly let you run Fluent or visa-versa. Mike
Old   June 29, 2006, 07:54
Astrid
I understand, but as Fluent and CFX are owned by ANSYS, an arrangement should be not be too difficult. And as they use the same licencemanger, same sort of file, only a different port number....
Astrid
Old   July 3, 2006, 04:52
Default what is the latest version of "Ansys CFX software"
Prasad
Sir,
Please tell me, what is the latest version of "Ansys CFX software"?
Prasad, Malaysia
Old   July 3, 2006, 17:10
Default Re: what is the latest version of "Ansys CFX softw
CFX10 with service pack 1.
Comparison of fluent and CFX for turbomachinery Far CFX 52 December 26, 2014 18:11
CFX or Fluent for Turbo machinery ? Far FLUENT 3 May 27, 2011 03:02
High Resolution (CFX) vs 2nd Order Upwind (Fluent) gravis ANSYS 3 March 24, 2011 02:43
Fluent and CFX Ale Main CFD Forum 7 July 30, 2008 21:14
Fluent Vs CFX, density and pressure Omer CFX 9 June 28, 2007 04:13
