What is mean by Normalized Force on Polyline 1? |
June 12, 2020, 01:40 |
Qazi Shahzad Ali
Rep Power: 8 |
Hi all,
What is “Normalized Force on Polyline 1” in cfx Post? Since cfx help manual does not provide any meaningful explanation to its normalized factor. I have a circular polyline, although it appears to be Normalized force, on the other hand, while on plotting a chart (Normalized Force on Polyline 1 vs Theta) it shows units of force [N] as well? Can somebody tell the real explanation behind this? |
June 12, 2020, 02:38 |
Rep Power: 143 |
Assuming what you are plotting is the Force variable over a line object - this is not meaningful. The Navier Stokes equations cannot exert a force on a line, only over surfaces (via pressure and shear stresses, both of which require surfaces).
June 12, 2020, 04:51 |
Qazi Shahzad Ali
Rep Power: 8 |
Glenn, thank you very much for the answer. You are absolutely right in your views about force on the line.
As per CFX help, forceNorm_x()@Polyline1 fucntion can find the force per unit width on polyline created by intersecting a locator on a boundary. However, in my case, this circular polyline (red color in enclosed pic) is created by boundary interaction of surface and vertical plane. I want to find flow induced forces (x, y directions so that to further convert into norm and tang comp) along the circular path at polyline location of axial flow (z-axis). The force_x@surface or forceNorm_x()@Polyline1 are not serving my purpose, so that particular reason I used Normalized Force on Polyline 1, which provided few results but I am unaware of its normalized factor and confusion about units [N]. If I am wrong, then kindly guide me how to find normal and tangential force component at particular location in any other possible way? |
June 12, 2020, 06:38 |
Rep Power: 143 |
Then you probably want to look at the line integral of pressure and the wall shear at the line, not the force variable. You will need to take account of the wall normal direction. Look in the CFX reference manual for all the variables you need to do this.
July 27, 2021, 14:34 |
Nidhi
Rep Power: 8 |
When you say line integral of the pressure and wall shear, do you mean lengthInt from the function commands? The length integral gives me information in terms of N/m or J/m2. Shouldn't the values be in terms of just N?
July 27, 2021, 18:41 |
Rep Power: 143 |
That is right, line integral of pressure will give N/m. So this is force per unit length, which is useful in interpreting 2D simulations. You multiply the N/m result by the third dimension length to get the total force.
In 3D you want an area integral of pressure to give a force. But easier is just to use the force() function.
July 28, 2021, 11:34 |
#7 | |
Nidhi
Rep Power: 8 |
The CoP Does not exist: Validating Aerodynamic forces through a "line of action" | ds4719 | Main CFD Forum | 14 | February 18, 2022 18:05 |
Drag Force Ratio for Flat Plate | Rob Wilk | Main CFD Forum | 40 | May 10, 2020 04:47 |
ActuatorDiskExplicitForce in OF2.1. Help | be_inspired | OpenFOAM Programming & Development | 10 | September 14, 2018 11:12 |
Normalized force on polyline in cfx results | asaleem89 | CFX | 1 | August 8, 2018 02:15 |
Force can not converge | colopolo | CFX | 13 | October 4, 2011 22:03 |
