What is mean by Normalized Force on Polyline 1?
Old   June 12, 2020, 01:40
Default What is mean by Normalized Force on Polyline 1?
Qazi Shahzad Ali
Qazi_Shahzad is on a distinguished road
What is “Normalized Force on Polyline 1” in cfx Post? Since cfx help manual does not provide any meaningful explanation to its normalized factor.
I have a circular polyline, although it appears to be Normalized force, on the other hand, while on plotting a chart (Normalized Force on Polyline 1 vs Theta) it shows units of force [N] as well?
Can somebody tell the real explanation behind this?
Qazi_Shahzad is offline   Reply With Quote
Old   June 12, 2020, 02:38
Assuming what you are plotting is the Force variable over a line object - this is not meaningful. The Navier Stokes equations cannot exert a force on a line, only over surfaces (via pressure and shear stresses, both of which require surfaces).
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   June 12, 2020, 04:51
Qazi Shahzad Ali
Glenn, thank you very much for the answer. You are absolutely right in your views about force on the line.
As per CFX help, forceNorm_x()@Polyline1 fucntion can find the force per unit width on polyline created by intersecting a locator on a boundary.
However, in my case, this circular polyline (red color in enclosed pic) is created by boundary interaction of surface and vertical plane. I want to find flow induced forces (x, y directions so that to further convert into norm and tang comp) along the circular path at polyline location of axial flow (z-axis).
The force_x@surface or forceNorm_x()@Polyline1 are not serving my purpose, so that particular reason I used Normalized Force on Polyline 1, which provided few results but I am unaware of its normalized factor and confusion about units [N].
If I am wrong, then kindly guide me how to find normal and tangential force component at particular location in any other possible way?
Old   June 12, 2020, 06:38
Then you probably want to look at the line integral of pressure and the wall shear at the line, not the force variable. You will need to take account of the wall normal direction. Look in the CFX reference manual for all the variables you need to do this.
Old   July 27, 2021, 14:34
Nidhi
nidhids is on a distinguished road
When you say line integral of the pressure and wall shear, do you mean lengthInt from the function commands? The length integral gives me information in terms of N/m or J/m2. Shouldn't the values be in terms of just N?
nidhids is offline   Reply With Quote
Old   July 27, 2021, 18:41
That is right, line integral of pressure will give N/m. So this is force per unit length, which is useful in interpreting 2D simulations. You multiply the N/m result by the third dimension length to get the total force.
In 3D you want an area integral of pressure to give a force. But easier is just to use the force() function.
Old   July 28, 2021, 11:34
Nidhi
Thank you for the clarification. I did use the force() function to get the total value. I wanted to get lift and drag values at different airfoil sections over the wing. The question was for that reason.
The CoP Does not exist: Validating Aerodynamic forces through a "line of action" ds4719 Main CFD Forum 14 February 18, 2022 18:05
Drag Force Ratio for Flat Plate Rob Wilk Main CFD Forum 40 May 10, 2020 04:47
ActuatorDiskExplicitForce in OF2.1. Help be_inspired OpenFOAM Programming & Development 10 September 14, 2018 11:12
Normalized force on polyline in cfx results asaleem89 CFX 1 August 8, 2018 02:15
Force can not converge colopolo CFX 13 October 4, 2011 22:03
