Reference Density (expression)
Old   August 3, 2006, 02:49
Default Reference Density (expression)
Marco
Can someone tell me what is wrong with this expression for Reference Density:
Reference Density = p/(R0*T) where R0=8314.5 [m^2 s^-2 K^-1](pressue is assumed to be in kg/ms2 I guess).
I got a warning telling that final unit is kg/m3K2, instead of kg/m3.
Thank you, Marco
Old   August 4, 2006, 07:44
Default Re: Reference Density (expression)
Mike
There's nothing wrong with the expression shown above... check you didn't enter it as p/R0*T, since that could be interpreted as (p/R0)*T which would give the warning message. However, I'm not sure if you are allowed to set a variable Reference Density, I think may have to evaluate to a constant, so it can't depend on the solution variables p and T. I could be wrong here though. Mike
Second Derivative Zero - Boundary Condition fu-ki-pa OpenFOAM 11 March 27, 2021 04:28
Error with Wmake skabilan OpenFOAM Installation 3 July 28, 2009 00:35
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
G95 + CGNS Bruno Main CFD Forum 1 January 30, 2007 00:34
Warning 097- AB Siemens 6 November 15, 2004 04:41
