Projection area
Old   July 14, 2006, 02:17
Default Projection area
Michael B
Is it possible to determine the projection area of an object in cfx post? Say for instance you what to determine the cw value of a car you need the projection area of the car. I have only succeeded in creating a plane at an arbitrary coordiante and calculate the fluid area, subtracted from the total area.
Old   July 14, 2006, 13:29
Default Re: Projection area
Robin
There was an undocumented command in 5.7.1 that did this (>dumpviewer file.txt), which would report the projected area of the visible surfaces at the command prompt. It doesn't appear to work in 10.0, however. Maybe it will get fixed for 11.0.
-Robin
Problem with reference area alfaben STAR-CCM+ 3 April 21, 2020 09:46
Non overlap area fractions saisanthoshm88 CFX 11 September 17, 2015 18:42
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
CFX Solver Memory Error mike CFX 1 March 19, 2008 07:22
