July 20, 2006, 03:34 |
How to calculate ave dinamic pressure?
I need to calculate ave dinamic pressure on a surface. I defined a new variable Dinamic_Pressure=0.5*Density*Velocity^2 then I calculated ave dinamic pressure in two ways: 1) areaAve(Dinamic_Pressure)@[Surface] 2) massFlowAve(Dinamic_Pressure)@[Surface] In the second case I have a dinamic pressure higher than first (about 200 Pascal). What is the best way to calculate it? Thanks |
July 20, 2006, 07:01 |
Re: How to calculate ave dinamic pressure?
Easient way to calculate dynamic pressure: Total pressure - static pressure
If the area over which you need the average is impermeable then the areaAve function is cleary the way to go as using massFlowAve on an impermeable surface is non-sensical. MassFlowAve is usefull for calculating averages on 2D patches through which fluid flows e.g. inlets and outlets. |
how does Fluent calculate the pressure and viscous force ? | e30.lsb | FLUENT | 7 | June 27, 2011 21:31 |
How calculate area of pressure below 101325 Pa? | eRzBeNgEl | CFX | 2 | May 5, 2011 09:53 |
Pressure Rise Error | emueller | CFX | 0 | May 5, 2009 11:08 |
Calculate Pressure with adding Hydrostatic pressur | Polly | CFX | 0 | November 20, 2003 22:58 |
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) | HB &DS | CFX | 0 | January 9, 2000 13:19 |
