Counter flow heat exchanger with two different liq
Old   August 2, 2006, 07:15
Default Counter flow heat exchanger with two different liq
Ram Dayal
I am not able to define two different fluids for a counter flow heat exchanger. Infact when I define fluid A for one channel and fluid B for another channel in the same domain fluid A gets replaced by latest defined fluid B. If anybody solved such problem having two different fluids not mixing with each other (please mind it is not multicomponent or multiphase problem.It is simple single ph problem having two fluids)
Old   August 2, 2006, 07:51
Default Re: Counter flow heat exchanger with two different
Mike
Set the environment variable: CFX5_NO_CONSTANT_PHYSICS = T before starting CFX-Pre. Then define a seperate domain for each of the two fluid regions - each will be allowed to have a different fluid. Mike
Old   August 2, 2006, 09:59
Ram Dayal
Thaks Mike for valuable suggestion Regards Ram Dayal
Old   August 6, 2006, 20:42
klarke
Having the following erro message,what should we do?
Error in subroutine FNDVAR : Error finding variable DENSITY_FL1 GETVAR originally called by subroutine GET_MFLOIP_ZIF
Heat Exchanger Model sak2129 FLUENT 3 September 26, 2017 01:29
Help !!! : Computation/Calculation of Heat flow through several layers of Glazing glazing Main CFD Forum 5 October 12, 2010 06:28
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 12:02
Heat exchanger! Alberto FLUENT 1 January 29, 2006 02:27
Natural draft heat exchanger Tamer Elsoukkary FLUENT 0 July 1, 2001 20:17
