Plot particles w. correct size?
Old   August 8, 2006, 02:22
Default Plot particles w. correct size?
Michael B
Hi. I'm doing some lagrangian particle tracking calculations with a particle distribution variying from 1 my to 100 my. While post processing I would like to plot the particles with the proper size (or multiplied by a constant), so small particles appear small and large particles appear large i.e a function of the diameter. At the moment all particles have the same size. Is it possible to do that with CFX-10 POST?
Old   August 8, 2006, 02:36
Default Re: Plot particles w. correct size?
Amit
I had also tried same thing few weeks back, but in vain. You can not plot the actual particle size that you have used for analysis. The only thing can be done to differentiate the particle size is to use different plot-sizes in the postprocessing. This postprocessing jugglery can work only upto some extent.
dpm and size of particles anissa FLUENT 1 July 20, 2009 13:36
Could small size particles be treated as gas? Nanazhu FLUENT 0 July 20, 2008 23:44
DPM - Why do the particles not vanish? Johannes FLUENT 12 July 6, 2007 11:19
What should be the correct size of mesh rajeev FLUENT 5 August 14, 2001 17:44
