Momentum source in a self-contained enclosure!!
Old   August 13, 2006, 23:19
Default Momentum source in a self-contained enclosure!!
Amod Kumar
I am trying to simulate the flow condition inside a Base Transceiver Station, an outdoor shelter used by telecommunication industry. It consists of varuious electronic heat sources, PCM budles and three axial flow fans, in a leaf proof camber.
The computational domain consists of a shelter having fans inside it to circulate the air. Their is no physical inlet or outlet.
For my CFD simulation, I need to add a momentum source in place of fan! Can some one guide me do that in CFX?
Thanks a lot,
Amod Kumar
Old   August 17, 2006, 07:56
Default Re: Momentum source in a self-contained enclosure!
TobiZ
Hi, I recently had a similar problem. I am not sure, but this might work: Create a subdomain or a source point and set a virtual continuity source. I think you need to set a mass flow source inside, and thus a sink with the same rate at another loaction (e.g. close to the source).
TobiZ
Old   September 7, 2006, 09:59
McDemmy
Have you tried running the simulation with a set of known initial conditions? You might have to do the calculation in two steps since your momentum source comes from results of initial computation. Good luck!
Enginetics
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
Simulation of Axial Fan Flow using A Momentum Source Subdomain Liam CFX 28 July 16, 2013 08:24
pisoFoam compiling error with OF 1.7.1 on MAC OSX Greg Givogue OpenFOAM Programming & Development 3 March 4, 2011 17:18
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
