Hi!
I have two subdomains where I need to apply momentum source terms in the tangential direction. These source terms are dependent on the radius and theta values in the respective subdomains. I have defined two new cartesian coordinate frames and applied these coordinate frames to the subdomains. Then using CEL, I have defined the source terms which contain r and theta. Does CFX calculate r and theta for each subdomain separately? It doesn't seem so, coz my source terms are calculated fine for one subdomain, but not for the other! Help! |
Do you have a local coordinate system for each subdomain?
Dear CF,
The CFX tutorial says source term = source coeff (U - Uspec, etc. Could you please guide me how to calculate source coefficient, Uspec, Vspec, and Wspec for an axial flow fan? I am modeling a fan in completelt enclosed cabin as momentum source. Thanks a lot in advance, Amod Kumar |
wmake compiling new solver | mksca | OpenFOAM Programming & Development | 14 | June 22, 2018 06:29 |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 16:02 |
[Gmsh] Compiling gmshFoam with OpenFOAM-1.5 | BlGene | OpenFOAM Meshing & Mesh Conversion | 10 | August 6, 2009 04:26 |
UDF Source terms not producing expected results... | Emmanuel Resch | FLUENT | 0 | July 31, 2008 14:55 |
Point implicit treatment of k-e source terms | andy | Main CFD Forum | 5 | June 9, 2006 11:03 |
