October 2, 2015, 11:06 |
Moving Coordinate Frames in Post
robo
Rep Power: 12 |
I am fairly new to CFX and CFD post. I have data from a past simulation that looked at a pitching body. I would like to calculate the pitching moment about a centre that is on the body but is moving; ie is not at the centre of rotation. I know that I can create a new static frame in CFD post that is in the right location and orientation, and then use the calculator to get the torque I want about that frame. However this requires me to manually update the frame every time step, which is cumbersome. Is there a way to automate this using expressions?
Find the value of the coordinate "z" when a variable exceeds a given value in Post | l.te | CFX | 2 | October 4, 2012 05:16 |
[Other] How to set up a dynamic mesh for a piston moving through a tube of variable diameter? | karkar | OpenFOAM Meshing & Mesh Conversion | 0 | July 4, 2012 06:54 |
Thermal model with mass transport on seperate moving coordinate frame? | evcelica | CFX | 9 | February 24, 2012 19:18 |
Moving coordinate frame | Roland R | CFX | 3 | November 28, 2011 09:59 |
C4 = 1 for Moving Mesh | Xobile | Siemens | 2 | January 18, 2005 05:22 |
