What to do if particle tracking fails (overflow)
Old   October 20, 2006, 03:21
Default What to do if particle tracking fails (overflow)
Felix
I am simulating a particle flow (Lagrange) in gas and got the following error for particle source change rates "NaN" and "Fatal overflow in linear solver". The first 2000 iteration steps the simulation were computed without particles until I got a stable T-profile. Then I started the solver again with particle tracking (high resolution) and after about 160 iterations this error appeared. Has anybody an idea how to find the problem or what the problem could be?
Old   October 20, 2006, 05:59
Default Re: What to do if particle tracking fails (overflo
Johnny
The solver crashed. Adjust your timestep, check your physics, check you mesh, etc., etc., etc.........
Old   October 23, 2006, 02:05
hdj
Check particle sources in out-file and try to change particle under relaxation factors.
hdj
Old   October 23, 2006, 02:22
Felix
Thank you, I will try that. For the last simulation I changed the blend factor to 0.75 instead of "high resolution", it was stable until now (about 800 iterations). I will let you know what happens when I change the relaxation factors.
Blood Damage Modelling via Particle Tracking in a Centrifugal Heart Pump scatman CFX 7 January 8, 2018 00:59
massless particle tracking problem Renold FLUENT 0 January 26, 2011 14:23
Particle Tracking for ion Jun CFX 2 August 31, 2010 08:19
Number density tracking rather than particle tracking Rebecca Main CFD Forum 2 April 23, 2009 12:52
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 01:29
